Topic: Removing spindle from control arm (Read 1362 times) previous topic - next topic
88TC...I am disassembling the front suspension to replace all the bushins and was wondering how to seperate the spindle/control arm.  My pickle fork aint fitting.
do you have the 'large' fork? i have a smaller 1 that's supposed to be for tie-rods.. works great for smaller balljoints
If everything is out of the car (it sounds like it is), loosen the ball-joint nut, hold the assy up by the spindle, and whack the spindle area around the ball-joint stud (Not the stud itself).  It will pop loose.
Quote from: Chuck W;379959
X100
this method works amazingly well
awesome, thanks.
Yep, take a BFH & do exactly what Chuck said.  Works every time!
I can attest to the validity of the a fore mentioned technique....popped right off.
