Topic: New member with a few pics (Read 3051 times) previous topic - next topic
Thats one sweet unmolested ride. I vote for you to keep it also.
1988 Thunderbird LX  557/C6 project. UPR tube K-member, A-Arms, Strange 10 way adjustable coilovers. SN-95 spindle,brakes. Manual rack, bump steer kit.  MM castor/camber plates, Dynatech 2 1/8 swap headers. Quick 9" 35 spline Moser axles,CHE lower c arms,
If I could solve the bucking / hesitation problem I would drive it and want to keep it.
Somebody help this guy, before he puts a for sale sign on it !!!!!!
If he puts a for sale sign on it I might buy it lol. I'm not too far from GA :)
Wow! Thats a keeper, throw some plugs, wires, fuel filter and spray out that IAC motor with some carb cleaner and go from there. That is a nice clean bird.
Light throttle surge could be the TPS. I'd start there.
I'd check for codes first...
Quote from: flylear45;379431
TPS was .86 to 4.88 and numbers moved up pretty smooth with throttle opening, timing is at 11, and it's not the IAC.
Quote from: daminc;379433
Trying to check codes but all auto parts stores will only test 96 and newer and I only have a digital volt meter.
Do you have a test light?  Follow this link for how to get codes with a test light.  http://www.extreme-check-engine-light-codes.com/Ford%20OBD1%20Decoder.htm
