Topic: Turning back mileage (Read 3992 times) previous topic - next topic
Got it figured out once you have it taken apart it's fairly easy just popped the little pin out and had my way with it. Thanks for all the help guys.
Quote from: dragon574444;378244
Do it the way Ferris Bueller would. It works on my 84 cluster, not sure about the newer ones. Just hook it up to a drill and have at it.
Your '84 cluster is cable driven. 85-88 clusters are electronic
A long time ago I got an buttstuffog '83 Coug (Silver) cluster and set it back. I don't remember the whole process, But I remember it wasn't very hard. Mostly just tapping out a metal pin, rolling the numbers as desired, and tapping the pin back in place.
Though it sounds like it's harder for an 87-88.
Quote from: V8Demon;378200
V8demon FTW!!!!!!
now if we could just figure out how to do it with an electronic/ base cluster :giggle:
Quote from: sarjxxx;379065
Run it up to 200,000 miles, it;ll reset back to 100,000. I read that a long time ago.
but what if 100,000 is still to much
