Topic: need to know asap - shock question (Read 2009 times) previous topic - next topic
Will shocks for 94/04 mustang work on a 88 thunderbird ...?
I know its the wrong section just need a deft answer before I buy
All Mustang rear shocks (79-04) are too short to use on the rear of a Fox Tbird/Cougar out of the box.  Even on a lowered car.
You can use them however, if you make up for the length difference.  Some folks use extenders on the top, some (like me) use brackets on the bottom that raise the mounting point on the axle up.
Will the front work with sn springs and sn struts with sn spindles ?
Quote from: thewestie;376361
Yup
Check
I Know someone who has put a check in the mail to run mustang rears :)
Quote from: thewestie;376365
Yup, just got it.  Sending stuff your way shortly.
cool :)
