Topic: 1986 XR7 351 turbo swap.... (Read 115149 times) previous topic - next topic
duh.. stock bore/stroke.. lol good reasoning, but if you ever build a stroker, i strongly recommend a custom grind.. OTS cams really suck in a boosted stroker.. i went through 5 cams before calling cam innovations.. unfortunately, it appears he's no longer making cams :(
Yeah a custom grind is always a good idea.  The Fcam will work for now.
Thanks,
Travis
Give Ed Curtis a call at FTI.. $325 for custom cam, sell you f cam.  For the extra ~$200 your combo will have more power and better drivability. Its going to pull the whole combo together IMHO.
Quote from: Bob;381836
Hmm.  It's a possibility.  One of my  many hurdles is that my fuel system this year will only do 600 rwhp.
Stock fuel lines!  Just no budget this year for the big fuel system.  I can probably make 550rwhp on 12psi
On stock stuff.  So wasn't really needing the cam to wow me.
Travis
I understand now, I really didn't know too much about F cams and turbos to be honest with you,  sorry for jumping the gun with my custom comment :) It's a whole different world with turbo applications that I wasn't aware of
I hear ya Bob.  With a turbo you dont have to have the perfect intake air flow to make good power.
The GT40 lightning heads are at the machine shop getting checked out.  If all goes well the engine should be installed mid March.
Travis
what size turbo are you using just wondering wanting to compare my setup vs yours lol. I have a staock 302 botem end and a f303 cam, it also has trick flow twisted wedge heads 170s but they have been ported dont know how big they are. Also i have blowthrough setup instead of efi so you got me there lol.
Cougar on a diet to suck gas and haul ass!
Cain, Pony Express Racing
I have a cheap 75mm with 1.00 ration exhaust housing.  Blow through carb is a great way to use a turbo setup.  Im a computer guy, so I like the EFI stuff.  Your biggest hurdle besides tuning is the failure rate of the 5.0.  People break the block with stock heads and cams.  So with your upgraded heads and cam, you will just make more power on less boost.  If you keep it to 450rwhp, it should last.....should.... :)
That is why I stepped up to the 351.  Yeah more cost up front, but the engine will stay together.
Travis
Received my 351 spider eBay nock off.  Looks sweet.  Also got Tue edelbrock Efi elbow.
Travis
Reply #39
You know a 351w max hp rating isn't a whole lot more then a 302 right? Maybe 50-75 hp depending on what year the engine is.
Reply #40
Quote from: snooking99;383253
Interesting....that is not what I have read on the net....many many times.  Do you say this from personal experience.
Travis
Reply #41
Balderdash.
Reply #42
HOGWASH! the factory 351w blocks are good for 750-800hp..
Reply #43
Well my response is....maybe the poster is mistaken..... :)
Travis
P.S.  the last thing I need is headgaskets?  I have uber arp head bolts.  Any ideas?
Travis
Reply #44
PS  I hope you are saying the Stock 351W block will make 750-800 REAR wheel HP??
 The 1974 Windsor block in my turbo car broke @ 675 @ the rear tires
 Just my personal expreince
