Topic: Super Coupe Motor In A Fox Body Bird (Read 11278 times) previous topic - next topic
To the OP: might check out sccoa.com for info, as well.
x2 on sccoa.. i signed up on there when i had my SC and learned a lot about the cars/motors, just by reading through some tech threads
Quote from: jonwayne1988;376028
OK so I'm going to use a 91 sc motor in a 88 tc so I can use the monuts off the 91 in the tc with no problems?
If you have them, use the lower U-brackets and the bushings from the 88TC with the engine brackets from the 91.
You may be able to use the 91 mounts as is, but you might need to elongate the slot in the K-member on the driver side.
yikes.. that's a bit of a dent in the wallet for a harness..
Quote from: jonwayne1988;376943
I was thinking about trying this wiring harrness http://www.ronfrancis.com/prodinfo.asp?number=MG%2D38
It's an EEC4 system.  No way in hell it needs a $600+ "custom" harness...
i'm still voting for repinning an NA 3.8 harness
What happened to this project?
I have the motor ready to go. But the car I was getting to put the motor in didn't happen. So I'm still looking for a body to put it in.
Reply #39
bummer hopefully you'll find something soon :)
Reply #40
Put it in a ranger. :burnout:
Reply #41
I have a seconed 3.8 sc motor for that too. I want do do the fox body swap first.
