Topic: Ok what do u think (Read 3398 times) previous topic - next topic
Ok what do u think
So last week my wife rolled my excursion so as I sat down to think what to do with it and it hit me how sweet it would be to put the v10 in the predator and back it with a t56 I need to research this some more, what y'all think v10 t56 or stick with the 351w and t5
Ok what do u think
A V10 would be cool I imagine you would have to make your own headers and motor mounts? But it could be done.
Ok what do u think
definitely interesting.. can't say i personally would ever do it, but i'd love to see someone else do it
Ok what do u think
Lol no actuly just a seat belt bruise it wasn't high speed but it was a 6 foot drop off in a ditch pluse the fact that it sat on 38's with a 8 inch lift I'm posting from my iPhone so as soon a I get to. A comp I'll post pix
Ok what do u think
I'd keep the 351. Put a 6 speed behind that.
Ok what do u think
V10 = meant for heavy, slow moving trucks pulling large loads
cast crank, probably, and speed parts are neither cheap, nor common.
Everybody that can read and doesn't live in a cave knows what a Windsor engine can be made to do. If you've insurance money coming from the Expy, order some Canfield heads (think Cleveland) and build yourself a 351 Clevor...and never look at a v10 again, except in your mirrors...
To put in a V10 would be the 2000's equivalent of stuffing a stock truck 460 into your car...of course, add about 70-100 more pounds, and even then, everything will need to be custom built to make it fit, and you'll NEVER get that mod POS under a hood, let alone stock..lol
Ok what do u think
The v-10's aren't bad motors, but they don't rev very high, and the wiring would be a nightmare. The 4.6 or 5.4 would be a better swap, but I know you already have the truck so yeah.
Just do a 351.
Ok what do u think
clevor has my vote.. my next dart block build will be topped off with aftermarket clevland heads and major psi supplied by a precision PT85 ;)
Ok what do u think
Quote from: BEARMAX;374960
Glad your wife is ok. now on to my opinion.  I agree with Beau, the V10 may sound like something cool to stuff in there but will be very costly and probably wont give you the results you are looking for unless you just want to be able to say that your car is the only V10 cougar!  351w would be my choice as there are almost endless possibilities for aftermarket parts and accessories.
Ok what do u think
The only thing I think they make for the V10 to fit in a fox is the oil pan, so everything would have to be custom. Its not a bad idea, Its just a 5.4 with two more cylinders. What holds back the V10 is its wait and lack of preformance parts. I would think that with some good cams and some head work it would run pretty good. I always wanted to put a V10 in my old fullsize bronco.
Ok what do u think
My dads car has a 351w world manowar block with chi cleavland heads on it, it is bored and stroked to 454ci and it makes right at 780 or so to the flywheel fastest pass is 9.27 in the 1/4.
Cougar on a diet to suck gas and haul ass!
Cain, Pony Express Racing
