Topic: whoever invented TORX head bolts was a friggen idiot (Read 5609 times) previous topic - next topic
MAP gas will work. thats what I use instead of propane
Quote from: ThunderbirdSport302;374505
I agree..lotta heat!
And graham, you need to go the LEFT way lmao ;)
NO!!  the right way..  if you go the wrong way it just wont work!!
I agree, you need at least MAP gas on the underside.  Once it slips out and strips when your twisting your kinda screwed.  I went through this on my wifes suburban brake caliper bolt, I was eventually able to get it by using a clamp to force the wrench and bolt together and hit it with a deadblow hammer after heating it.  You cant get a clamp or anything in your case though.
Mike
I agree, whoever invented TORX head bolts needs to be shot. JK
If it wasn't so close to the bracket, you could use a small pipe wrench to grip the outside of it. Looks like it twisted the bit also, might try to find a straight quality hardened steel bit and hammer it in as suggested. Good Luck.
Map gas all the way!! Heat it from the bottom and it'll come right out.
Or
It's still available here in Indiana Tom
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
same here, i saw it when i went to the parts store yesterday to pick up tail light bulbs and sockets
Yes i
If I had a nickel for every torx fastener I have cussed out.... well, I'd have my car done by now, lol
good hammer shots released the torx...
