Help! May 29, 2005, 03:15:03 PM ok i just got my AC fixed on my 87 tbird and now the condensation off it is building up so much that when i go around a corner like a cup of water spills out over my feet. is there a pipe or something back under there thats clogged or what?Plz help that water is COLD! Quote Selected
Re: Help! Reply #1 – May 29, 2005, 03:36:00 PM On th pass side of the firewall,below the a/c dryer(black cylinder bolted to firewall)is a small black tube that just barley pokes out.It can get clogged up with spider webs and then the condensation will build up in the heaterbox.Blow through the hole with compressed air or stick a small object sush as a screwdriver up through the hole to dislodge the blockage,water should start pouring out. Quote Selected
Re: Help! Reply #2 – June 01, 2005, 04:27:11 PM that's actually kind of funny. at least you know its working!! let us know if you get it fixed... Quote Selected
