Topic: my 88 t-bird (Read 4947 times) previous topic - next topic
my 88 t-bird
Quote from: cougarman;373896
I removed the lenses from the housings. I started with 320 grit to remove all the yellowing, and moved up to 600 wet 800 wet 1000 wet and then 1500 wet. I then machine polished them with two grits of polishing compounds, and finally a hand glaze. Came out pretty good.:D
nice... Its going to be a bitch removing the lenses... I tried to see if I can loosen them last month when I tried to clean them.
my 88 t-bird
You could always just rermove the whole assembly, and polish them that way also. I mainly took the lenses off so I could paint the inside of the housings. :)
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
my 88 t-bird
btw, I just discovered the car radio is I guess I can say bolted in? Was able to remove the 4 star screws, but got stopped by something else. Anyone know how I can remove it?
my 88 t-bird
After the screws, it should just pull out. It has a kind of clip on the bottom that keeps it braced. Give the stereo an assertive, yet nice, pull. It should slide out. It is the factory stereo, right?
my 88 t-bird
Quote from: vinnietbird;374011
Yes
