Topic: First bird (Read 2638 times) previous topic - next topic
First bird
i know this doesn't pertain to the topic at hand, but a taller sidewall is better for slicks as well.. not saying run an overly huge tire, but if you watch the sidewall as a powerful car launches, you'll see the sidewalls wrinkle.. a lower profile slick wouldn't hook nearly as well, because it will loose that wrinkle, which believe it or not, helps the tires stay hooked when you launch.. and that's without even getting into the different compounds
First bird
I generally run the pressures in my tires low. Makes the car shift harder when you go around a corner, and it gets sideways easier. Also beats the  out of your side walls, and you get slightly worse mileage.
First bird
cab drivers do that to rack the meter up :giggle:
