Topic: Need help FAST !!!!! FIXED !!!! (Read 36900 times) previous topic - next topic
Reply #240
I pulled the stereo, a/c controls, and sentry panel. No sign of a bad wire anywhere I can see. Maybe it's in the cluster. I'm getting a replacement soon. Car funds are gone, acquiring more as we speak. EVERYTHING works except the two outer passenger side signal lights.
Reply #241
Vinn
Reply #242
Possibly the burned up wire could not be allowing enough voltage for the sequencer to sequence. Too bad U don't have a DVOM.
Reply #243
I'll try to back probe the wire I repaired tomorrow. Maybe it is the sequencer. I don't know how to check the sequencer. Yes, it's wired right. It's been wired for a few years, and as of last month, all the lights were working. I was showing them to a Stang guy. It all happened after the core swap. SO, I still have to figure out the outer two lights.
Reply #244
The burned up wire is repaired, but still no outer lights.
Reply #245
Vinny
Reply #246
Vinnie, what lights are out exactly.... parking lamps? front and back? or all ?
Reply #247
If that sequencer is made with solid state electronics it didn't stand a chance of surviving a short like that.
Reply #248
If TC was right, and front turn signal and rear turn signal are two different circuits, it makes me wonder what caused the short in the rear wiring.
Reply #249
The exact light issue Jerry is the outer two rear passenger lights. That's it. Everything else is great. I have no idea unless it is the sequencer.
As far as what caused it, who knows/ Probably sliding the dash back in place and compromised a wire. All I can figure.
The rest of the lights, inside and out are working as they should. Only those two are inop.
Reply #250
are those the running, and side marker lamps?
Reply #251
Just the two outer brake lights.
Reply #252
no lights on at all..
even with brake on, or with lights on?
Reply #253
No brake lights. They come on with the headlights. Just no brake lights, or emergency flashers. When the brake pedal is pressed, only the inner light comes on.
When the signal light is turned on (passenger side), only the inner light comes on.
When the emergency flashers are on, only the inner light comes on.
Reply #254
i'm willing to bet it's the sequencer.. i know, i sound like a broken record lol.. but if your inner most light is working, your sequencer IS getting the turn/stop signal from the front of the car.. at this point, it makes more sense than anything else. without a doubt, the sequencer is getting signal, but it's not sequencing.. it's a shame those things are hard-wired and not set up to plug in.. if that was the case, you could swap the driver side sequencer in and i bet all 3 bulbs would light up.. if i had a sequencer, i would send it to you to try out, but.. i don't
