Topic: Need help FAST !!!!! FIXED !!!! (Read 37005 times) previous topic - next topic
Reply #150
Alrighty then. Hey, what color are the wires to the brake light switch at the pedal?
Reply #151
electrical noob lol
Reply #152
Quote from: vinnietbird;371788
LG/R (Light Green with Red Stripe),  LG (Light Green)
Reply #153
Here we go...........
Reply #154
Reply #155
Here we go...............
Reply #156
Couple more.........
Reply #157
Fuse 13 receives power from the Main Headlight Switch, terminal "i" (illumination) which is the output of the dimmer control.
Fuse 13 feeds circuit 19 LB/R (Light Blue / Red) which powers the Illumination Lamps of the following:
Console Ashtray
Instrument Cluster
Radio
Clock (buttstuffog)
Cigar Lighter
AC/Htr Controls
Graphic Equalizer
Main Light Switch illumination
Reply #158
One more...
Reply #159
Yep, that is the one...lights-on power from the switch to the dash.
This situation has all the hallmarks attribUted to that wire, IMHO.
Reply #160
hwy73, Thank u so much for the diagrams! Now I can see what everybody is talking about. This fuse 13 is a great find. He may have a long road ahead, but at least he knows which way is north. What do you see for tail lamp illumination? I would like to see the connection between this fuse and the left tail lamp.
Reply #161
Chrome, it's the right side (passenger side) tail lights that don't work...actually, the outer two lights. The inner is great.
I have to drop the fuse panel and look at the wire again. I'm sure it goes a few inches than into a taped bundle. Where it goes from there I'm unsure.
Could the light switch cause all that?
From my understanding, which is saying very little, I need to trace the LB/R wires from cluster,console, light switch, a/c illumination ,lighter,and clock and see where they go, and if they're damaged at all.
I don't have a volt/ohm checker.
This is like advanced Trigonometry.....which I didn't do, and glad of it.
Reply #162
Quote from: EricCoolCats;371806
Eric, you're speaking of the LB/R wires?
Reply #163
Sorry Vinnie, It's been a long cold windy day. I work outdoors.
Reply #164
Sorry for what? Jump on in to this chaos.
