Topic: m90 blower help needed... (Read 2221 times) previous topic - next topic
I have a carbed 5.0 and I just put together this m90 on it.. NOW, Is there any way to make the snout of the blower longer?? can I buy longer ones to fit the m90?? Any help would be greatly appreciated .. Thanks in Advanced guys... AND does anyone know the stock psi..?
Re: m90 blower help needed...
as far as i know, the snout length is what youre stuck with
stock PSI...PSI is relative, for example, that blower on an SC should put down 15psi, but in a V8, could possibly put down 8psi, it depends on the engine, setup, etc
in an SC, they put down 15psi
im pretty sure your stuck with the length... but maybe you could get somebody to machine a pully for ya. just make it longer if its not that much ya need.
i need alot added on to the snout if i cant buy one... i guess maybe ill just have to do with what i got..
Hey, I got an M90 blower laying around that I have been planning on putting to use in a 5.0L project.  Just curious how you mounted yours and hooked up the inlet and outlet to the intake track.  That and how is it mounted to your motor.  Got pics?
Source: http://www.capa.com.au/eaton_m90data.htm
Different length drives are available, giving the custom installer flexibility in the placement of the supercharger.
Just ran across this today.
yeah man, you got any pics? i gotta see this
Looks like you gotta contact the company if you want a custom job like that.  Judging by their prices on the unaltered stuff I'd say that they would charge an arm and a leg.....
That website is in Australia.. don't take those prices completely to heart.. although I'm sure it still won't be cheap.
ill have pics soon, also , my motor is carbed so I dont have to worry about alot of stuff that the fuelinjected 5.0's do.. Its pretty easy though, just alot of measuring and cutting.. the hardest thing was to make it seal tight.. cause I had to worry about gas leaking, not to mention air.lol. Its welded up tight though , you'll see in the pics.. Thanks guys for all your help...
