Topic: Heater Core question..... (Read 3745 times) previous topic - next topic
My 93 ranger had the antifreeze smell...Couldnt ever find a leak, fluid level never dropped. Bypassed the HC for about 2 months before it was impossible to drive without heat because the freezing rain would stick to my windshield...So I ran water through the HC via a waterhose to flush it before I reconnected it (Didnt have money to get it replaced, had a broke leg and minimal tools) After the flush and reconnect, approx 35,000 more miles on it and never smelled coolant again.
My first heater core swap was 9 hours, the second was 7, and then down to a little less than two. Still no fun, but WAY better than the first time. I really don't think it's the core. I'll post something one way or another today on my findings....or lack of findings.
Are they Ford cores?  You have the hose restrictor in??
Mike
No, and yes. I drove the car this morning for about 30 minutes, and no antifreeze vapor on the glass. Crazy stuff.
I'm still not seeing an signs of bad core, but, I can't find anything else. I'll change it at the end of the month as a "just in case" before the cold gets here.
I found this link in my bookmarks. It may help or at least give more detail.
http://www.coolcats.net/help/heatercore.html
Quote from: QUICKSHIFT;370385
Thanks a lot. Changing it is no big deal. I have it down to a science now. I just don't want to.
Friday evening, or Saturday morning, I'm swapping the heater core out. I'd like to start today, but have c to tend to, so, I'll let you know how it turns out, and IF I can do it without disconnecting the a/c. IF I have to disconnect the a/c, it's only $40.00 to re-charge the system, so, that's not too bad.
