Topic: turbo bolts? (Read 1019 times) previous topic - next topic
turbo bolts?
What grade bolt/stud should i get to hold on the turbo elbow?
turbo bolts?
They're metric, so a class 8.8 or 10.9 is probably all you'll find. I've used class 8.8 with no issues.
turbo bolts?
Okay thank you very much for your help jangus
turbo bolts?
What about a gasket for an external 5 bolt elbow? I cant find any...
turbo bolts?
You shouldn't need one. The  on that elbow whould be FLAT, as should the one on the turbine housing. Put it together without a gasket and test it before you go and buy a gasket.
turbo bolts?
Oh alright cool. Thanks for even more help!
