Topic: 88 'Bird GFX kit, TC PRC struts/shocks etc...... (Read 2513 times) previous topic - next topic
Many more parts added. I'm what you would consider a motivated seller, will offer discounts on multiple purchases.
Your Inbox is full.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Cleaned it out. Should be good to go now.
hey are the inner lights for a turbo coupe if so how much for a pair of inner lights and good condition headlights?
Bumpity.
I will consider all offers, even ridiculous ones. I need the garage space for a future resto project, and this stuff is in the way.
Do you still have the shifter boot, I broke the plastic shifting to second to aggressively :(
I'll take the 20 tooth speedo gear....PM sent :)
