Topic: Interesting find at the junkyard (Read 2431 times) previous topic - next topic
Cougar with an H/O swap
anyone need anything?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Whats the interior look like in that Carl?
It was almost 100% gone or trashed.  No 140 MPH speedometer.  There is also a 20th anny with a few good interior parts.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
OK, thanks man.
It may just have an H.O plate on the intake. That's my guess. Never know til you check the firing order.
I'll give another look when I go there again.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Quote from: vinnietbird;369535
+1 on this.....
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
is it an aod with a floor shifter car?
And the injectors :)
Quote from: ThunderbirdSport302;369591
Don't the HO versions also use the same 19 lb injectors like the non-HO ??
To the O.P.:
If the upper intake is loose, take a look under it.
 A real H.O. upper will have the letters H O cast on the bottom side.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Nope, SO uses 14# injectors, my bet is it's just a plaque.....lol.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Not sure if there's an "HO" casting under the intake, but I DO know there's a little "HO" cast under the plaque on true HO intakes..
Quote from: ThunderbirdSport302;369702
Yeah, you're right. I had a brainfart there.
It's under the upper where the casting number is.
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
Quote from: cougarman;369683
Didn't know that..... what color are the 14  pounders ?
83 T-Bird 460
84 T-Bird 5.0
95 Mustang GT auto
14# injectors are grey.
Matt
