Topic: Smog pump delete kit... (Read 2081 times) previous topic - next topic
Awesome, thanks appreciate it.  :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Have you tried ebay? That's where I got mine a couple years ago.
Quote from: 1Bad88tbird;368747
Yep been looking, I like the short belt idea though.
I'm interested in the short belt too... may as well take mine out, as long as it connects to nothing anyway
I wish I would have saved a part #.
I did mine on the side of the road in 20 minutes when my belt locked up.
If you delete it, there are some vacuum lines, and a metal tube that runs off your heads and to the exhaust.
All you have to do is un-bolt it and find the right length belt. 5 minutes and free.
I used a short belt for a long time, then when I installed the a/c, I found a delete pulley for the smog for $20.00 and got it. Main reason was so that I could just toss on a stock length belt that I had on the garage wall since until a/c, it was a/c delete....an even shorter belt.
Quote from: Haystack;368829
Oh you mean all the  that's in the junk pile right now....lol. Yea really cleans up the engine bay on that side.  :D
I got the part number off the belt. It is 6K860.  Means it is 6 rib serpentine, 86.0 inches long.
This is all stock pulleys.  Underdrive will change the length.
Mike
Thanks I appreciate your help.:bowdown::bowdown:
