Topic: 83 5.0 CFI.. EEC-III or EEC-IV? (Read 5723 times) previous topic - next topic
which would it have? i found a couple tech articles explicitly saying it's EEC-IV, but a guy on SBF Tech PM'd me, insisting it's EEC-III and he's willing to bet all of this auto knowledge on it.. aren't the square pre-82 birds the 1's with EEC-III's?
here's the easy way to put this to rest.. is the EEC-IV for TBI or MFI? 85 was the last year for CFI/TBI and 86 began the MFI/multi port.. i'm going to drop kick the people who wrote the pages i was reading if the IV is an MFI ecu
a quick ebay search shows some 84-85 EEC-IV's and some '85-94' EEC-IV's.. sooo, is it possible that the EEC-IV was used in the 83 5.0 bird, since it was a mid model year launch? the 5.0 and TC birds weren't released until feb of 83
83 5.0 CFI EEC III, 83 Turbo EEC IV,  83 3.8 Carb.
Early 84 5.0 CFI for California EEC III.
All other 84 -88 CFI, EFI and Turbo EEC IV
Except for Canada which had Carbs on 83-85  5.0 and 3.8
so, in other words.. with the EEC-III, the ignition would be run off a module(ICM) like so.. correct?
Quote from: Shadow;368189
Yes. It uses a Duraspark III ignition module.
Also the distributor has no stator or hall effect emitter and no vacuum advance. So the only wires to the distributor are the plug wires and the coil wire. There is no timing adjustment.
A crankshaft position sensor sends a PIP pulse to the EEC. The EEC sends a spark out pulse to the ignition module.
no wonder these cars old had 140hp.. they were set up so retarded.. playing with this thing is NOT going to be fun.. lol
tell me about it, can't wait to rip it out and raplace it with a HO motor :P
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
i don't have that option with this car, since it's not mine and is staying 100% original to the detailed eye.. it's either i find a way to make it work or build a mega squirt ECU to be compatible with the OEM harness, but i reeeeeeaaaaaaallllllllllllllllly don't want to take that route
Quote from:
Except for Canada which had Carbs on 83-85  5.0 and 3.8[/QUOTE
  MY 84 is a Canadian and had CFI.
so far, from the info i've gotten from sbf tech and some googling (and the tidbit of info here), it looks like the best bet is to upgrade to EEC-IV and disguise the harness as the EEC-III setup.. the AC bracket and compressor will hide the distributor module. the rest i can run under the hood to look exactly like the stock EEC-III harness and leave the duraspark III ICM in it's place, with a dumby harness
Quote from: Shadow;368292
Sounds interesting, keep us posted.
tbirdregistry.com
26480
27373
there will be a large thread with tons of pics of the car.. it's a full on resto i'm doing for a member here
