Topic: AOD Cooler Options?*pix of mine pg 2 (Read 5382 times) previous topic - next topic
I am
Quote from: TOM Renzo;369064
Note eliminating the radiator cooler and running a separate cooler only can only be dun in a worm climate situation .
so if the car is a summer driving car only... it would qualify as a warm climate situation?
Yes
Tom,
Thanks for the heads up, ill get it fixed.
I kept reading the upper fitting is the one to tap into, but they were referring to the upper on the case, not the radiator. Wow, doofus. Now that Im getting dirty again, Im thinking about bypassing the stock one alltogether. Houston definitely qualifies as a warm climate. Is the hayden 679 a large enough cooler to handle it on its own? I wish it has threaded fittings, Id just get braided line for the whole run. I have a childhood friend who owns a chain of hose and fitting shops.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
Th
