Topic: Pulling Engine- do i have to remove hood? (Read 4169 times) previous topic - next topic
1986 cougar with v8.    can I pull the engine and trans (as one piece) if hood is propped up as high as it can go?  Or do i have to remove the hood?  in its highest position the hood is just about perpendicular / straight up and down.
I'm guessing you might be able to get it out, but I found with the mustang, not having the hood in the way makes things a lot easier. If you mark the hinge positions before unbolting, it's usually pretty easy to line up!
Pull the hood. it's only four bolts, and it'll make things a LOT easier all around.
ok.  i figured it oughta come off.    wishful thinking......is why i asked.  i took a hood off another car one time and it took me forever to get it back on correctly.
Just scribe a line around the hinge onto the hood. That leaves you a traced guide line where to put the hood when you re-install it. Or use a Sharpie marker, grease pencil, whatever.
Whats the big deal with removing the hood its just 4 bolts I usually lay a heavy blanket on the roof and just lay the hood on the the blanket.
87 TC
Quote from: bigbada1;367237
I don't think it's the pulling of the hood it's the lining back up that can sometimes be a PITA if you don't mark the hinges...
FOXLESS!!
1994 Lincoln Mark VIII
Engine and trans together? No won't work. Engine alone? Yes. How do I know? I did it. Easy.
Hood is off.  I marked it well.    In addition to the hood,  if I also remove the Johnson Rods,  should I mark what side they go on or are they fully interchangeable?
WHAT is a johnson rod? Is that some kind of North east slang?
Quote from: vinnietbird;367280
:dunno:
Quote from: mattg;367278
  I marked it well.    also  the Johnson Rods,  ?
I got a mark on my Johnson rod once, its a long story.  Not in the sense you think I said it was long.
 I mean I dont have a log.  "weak reference to Chevy C."
Mike
Still wanting to know what a Johnson rod is. I know what it sounds like, and hope I'm wrong.
Quote from: vinnietbird;367312
yea, I hope your wrong too..
