Topic: 84 5.0 EEC-III Engine dies at idle randomly, rough idle at times, runs great at speed (Read 6499 times) previous topic - next topic
Does the exhaust smoke a little when you restart after it stalls? Having to open the throttle to restart sounds like it is flooded.
On the ECT, I should have told you to check the voltage between the two wires to make sure the signal return is not an open circuit. That is put the red meter lead on one wire and the black meter lead on the other wire.
When it does the hiccup, the 02 sensor voltage shoots up (0.7volts and above).....so it goes rich when it runs like . So then I go crank it, no start. So then you have to open the thottle to start it, and some of time it will shoot a flame up the TB when it fires.
I did put the leads between the sensor leads, the voltage was lower.....i want to say about low 7volts. When it was wire lead to battery....it was about 7.8volts.
I appreciate your help.
1984 T-Bird Elan 5.0 (sold)
1994 T-Bird LX 4.6
2009 Dodge Charger Daytona 341/400
2013 Camaro SS
Does it have a spout? If so take it out, sounds like your timing is jacked with backfiring out the TB.
Does this have the "brain box" on the fender? If so check that guy.
No spout. It's EEC-III. Timing is not adjustable. Has a crank sensor that feeds the ignition module.
Yes it has the ignition module on the fender, even that was replaced.
1994 T-Bird LX 4.6
2013 Camaro SS
When it stalls, check to see if one of the injectors is dripping fuel, not sealing.
Try running with one injector unplugged then the other unplugged.
Funny that you said that....
I did that too last week....it runs but barely/rough on one injector at a time....and both sides seems the same roughness.
1994 T-Bird LX 4.6
2013 Camaro SS
Where is the pcm located and how do you get it out?
Can you remove the injectors with the TB on the car? What's the trick to remove the injector from the rail/TB?
1994 T-Bird LX 4.6
2013 Camaro SS
Quote from: Smkn600ctd;368097
On the EEC IV the EEC is behind the passenger side kick panel.
Never done it, but pretty sure you have remove TB.
Quote from: Smkn600ctd;367940
It only does its BS once it warm, and only after about 2 min after it restarts.
Sounds to me like it's going nuts when it goes to closed loop, just for grins disconnect the O2 sensor and see if that changes anything... At 27 years old the computer may well have a issue, I had bad capacitors in my '93 Lightning PCM that made it go nuts(which I replaced and it's fixed)... Still I would not replace the ECM till all the other possibilities were covered...
One more thing, you mentioned the idle dropped with the A/C on, sounds like the ECM isn't sending a signal to the idle motor to increase speed...
That's exactly my thought that is going on. The question is why it's going nuts.
The car doesn't have a idle motor, just this vacuum kicker/dashpot. When it starts going nuts, you see the kicker and the fast idle pulloff (their are both controlled by the same solenoid and same line) kick out and then back.
The only thing not replaced at this point is the crankshaft sensor and that's because it's a major undertaking (remove alt, smog pump, it's bracket and everything else associated with it)
There is 83 eec3 car at the pick a part, so a PCM would be cheap. But how do I get it out/location?
1994 T-Bird LX 4.6
2013 Camaro SS
The ECM should be in the passenger side kick panel(the IV are there)... Probably will be a support bracket that has to be loosened, also the electrical connector will have to be removed before it will slide out...
Swapped in a different ECM...........same thing.
Was playing around with the ECT, and it looks likes runs better with it unplugged. Sometimes it will start with it unplugged, other times it has to be plugged in to start. If its running and you unplug the ECT, it will sometimes die or I can plug it right back in and unplug it....then it will run.
Watching the 02, it running at .1-.2v, then will hiccup and it goes to .7-.9v at idle.
No wonder why the techs used to call these cars "run-away cars".....
1994 T-Bird LX 4.6
2013 Camaro SS
IT PASSED!!!!!!!
The numbers were flat out awesome....flew right through the dyno smog test. 37 HC 0.01% CO 277 NoX
Then while idling....it died. Had not died in three days, just the hiccup and lowering idle. While I was there talked to a old school ford mechanic who thought it could be fuel pressure regulator maybe malfuctioning.
So half the saga is done.....
1994 T-Bird LX 4.6
2013 Camaro SS
So I spent all day f-ing with this car.
Changed the fuel filter.....no better. Ohm checked each of the solenoids.....all in spec. I double checked the ect and act. Swapped map sensors back and forth. Egr position sensors swapped for old and back to new.
I give up.
1994 T-Bird LX 4.6
2013 Camaro SS
change the crank sensor if its one of the last things left, if its bad it would explain why the motor loads up with fuel, the spark cuts out and loads the exhaust - o2 spike at stall
