Topic: brake booster adj. clutch cable wich one????? (Read 1701 times) previous topic - next topic
Hey, guys I need to know what booster I need to work with my adj. clutch cable, going today so I can be ready early tomorrow morning to finish up
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Do you mean for the firewall adjuster to fit right? A Fox 5.0 booster is a direct swap, and smaller than ours. It allows plenty of room for the adjuster. I kept my stock adjuster and just do the adjustment at the tranny end of it.
do you mean a stock 5.0 "mustang" fox
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I went with the 87 gt booster and master Ive since changed to the 93 cobra 1" bore master and wish I'd gone with the 93 cobra booster so my 2 cents is 93 cobra booster and master specially with big brakes
Quote from: 347Thunder;366094
Yes.
got a 1990 mustang booster, came out great
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
