Topic: 302 Running like . Still can't find issue (Read 3972 times) previous topic - next topic
Yes Vinnie i was just showing the difference in the connections. The difference in the sensors is minimal but they are slightly different. One converts Vacuum into a resistive value and the other reads Barometric pressure. Both sensors produce the same resistance when they are at atmospheric pressure. So either one can be used as a BARO SENSOR OR MAP SENSOR. I actually did a comparison on both and their performance is similar. But they do carry a different part Number. I would venture to say they are slightly calibrated for different applications. Example my MUSTANG has 2 part numbers for the TPS sensor. One is tuned for a different emission parameter. But the auto part store only lists one TPS for my car. The sensors are slightly different but close enough i guess by application Thanks
You can also remove the valve cover and see the timing events. Or rock the damper bolt back and forth to see the chain stretch. But a compression test will expose a jumped chain faster than a 3 LEGGED CAT RUNNING OUT OF A DOG POUND.
^ :bowdown::rollin:
Ok so being the stupid person i am.. i can not find my compression test kit at home. I will run down to the shop tomorrow and post the compression test readings and will run codes again.
Thanks a ton everyone.
[SIGPIC][/SIGPIC]88 TBird-5.0 Cobra engine, Fresh Paint, BBK Cold Air Intake, Aluminum Driveshaft, Brian Crower Cam, Nitrous, 5 lug conversion, full cobra breaks/rims assembly, BBM shift kit, Maximum Motorsports Caster cambers/shocks/struts, Eibach Springs, Mass Air Flow Conversion, HEI Distributor, Compression rate 10:1, 2.25" dual Magnaflow glasspacks- Ford Motorsports short headers, 70 mm tbody/egr/upper, 1 inch spacer on manifold & more
Quote from: TOM Renzo;365730
Thanks Tom. I appreciate that info. When you're down in Southern Oklahoma, I'll buy you supper.
