Topic: Max potential of E85 with Brown Tops and Kirban FPR? (Read 2049 times) previous topic - next topic
I already have the 120lb injectors from stinger, but am waiting for a PIMP ECU before I install them.
In the mean time, I was wondering about how much horsepower the brown tops can handle with max fuel pressure from the Kirban and Walbro 255.
I was also wondering if any place sells a reman kit for the brown tops resistant to E85?
Thanks!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
You will need to rebuild your entire fuel system for E85 and use special injectors lines pump Regulator and so on and so forth ETC. The problem with E85 is its cleaning effect an some say corrosive nature. I run 30% on a car we did but that's it.
http://www.diyautotune.com/catalog/delphi-85-lbhr-ev1-style-fuel-injector-lowz-p-279.html
I already have everything I need for E85 minus the ECU. Walbro 255, Kirban FPR, Lucas 1260cc new lines.
I have already run E85 several times with no problems at all, but was wondering what the max potential is with elevated fuel pressure on the brown tops.
btw, from what I have seen locally and online it looks like most of the things people say about E85 are myths.  Several people I know have been using E85 on stock components with no problems at all except that it runs leaner than Gas due to lower BTU properties.  Which is why I got 1260cc injectors.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Increase fuel delivery by 30%. For E85. Their are lots of MYTHS but FLEX FUEL engines have all different components. Its not a MYTHS its fact that all Flex fuel engines have different components. Otherwise all the car makers would just recommend using it with no ISSUES other than a STOICH CALIBRATION
Fair enough. I will be careful using it. Thanks for the info!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
I hate that gas my tahoe looses about 2-3 mpg's with that , it's not even worth running on an everyday basis unless it was $1.00 less a gal.lol
Not helpful just saying:punchballs:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
True thunder but you can make some NASTY HP numbers with the stuff!!!!!!
really? cool I did see that quick fuel makes a cool looking green one????? No, I don't need any more adventures,  this stupid car I love so much.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
