Topic: New Diamond Head Lights for the '83 (Read 11619 times) previous topic - next topic
Are those relays Bosch brand?  I haven't been able to find any relays under $20...so my relays are still the cheapo ones that came with my harness.
go to the junk yard and find a hard top sebring and on the firewall there are 3 relays, cut them out, solder new wires and they only charge like $5.00, if you want some let me know and I can get a set, I used them for my accessories and I just got a set for my lights
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Another option is to use a power distribution box from another car. In the 86 I used an sn95 box for the cooling fan, and headlights. (Attached to drivers side strut tower like the SN)
very nice, I thought of that but that looked like a lot of wiring.
:punchballs:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I order all of my stuff here:
http://order.waytekwire.com
Last time I ordered the Bosch relays they were about $3 each and I ordered a box of 50.
Here is the wiring diagram for the way I wired my lights up.  I put the factory wire colors on there as well but this is for an '83.  It should be pretty easy to figure out with a test light so I would do that to make double sure its correct on your car.
X
Darren
Subscribing
what wattage bulbs are in there?
The standard H4 bulbs are 100W on the high beam side and 80W on low beam side. So it pulls 160W on low beam and 400W on high beam.
Darren
I think they sent me something lower wattage, my low beams are low, I will have to try another bulb in one and see.  By the pics, my high beams look like your low beam
Did you rewire them with relays? Call who you bought them from and see which bulbs they shipped with. Another thing to check is the grounds. If they are not 100% them the light output will suck.
Darren
