Topic: 2003 Mach 1 Springs (Read 11812 times) previous topic - next topic
2003 Mach 1 Springs
Makes the ride even rougher though.
If mine doesn't sit how I'd like it to when the rear is finished, I'll probably cut my TC springs and try those.
2003 Mach 1 Springs
i'm still very happy with my SN-95 springs. Now, I got them for free. If I had to pay, I may still have the stock springs under there.
2003 Mach 1 Springs
Any new pictures?
 I'm having my springs put in today or tomarrow.
 I just want to compare the tbird and cougar stance. I'm  also useing Mustang front springs @ 1.25" drop from Steeda.
2003 Mach 1 Springs
I went back to work so I took some time off but I should be done this week and than I'll post some more pics .
2003 Mach 1 Springs
Before....
After the SN-95 front springs...
2003 Mach 1 Springs
About 1.5 inches in droppage.
2003 Mach 1 Springs
Quote from: TOM Renzo;363642
Here you go this is how we do it. It increases the spring rate a lot and it lowers the car 1-1 1/4"
http://i600.photobucket.com/albums/tt88/tomrenzo/Kitties244.jpg
Hey Tom, what spring is that? Is 1-1 1/4" after the car settles? Thanks, Herb.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
2003 Mach 1 Springs
I stopped for a little while to wait for my buddy to plumb my brakes . With the extra time on my hands I installed an 87-88 Turbo coupe 8.8 rear and CHE control arms. I'm going to have the rear rebuilt with a 31 spline Detroit locker which I already have, 4.10 gears which I already have, 31 spline axles and 99-04 brakes which I don't have yet . My buddy who's going to do the rear end work said it did'nt matter to him if the rear was installed or not so I put it in .  My only problem now (besides a lack of funds :mad:) is that my fox tie rods are too short to fit my 99 spindles ( I thought I had 98 spindles but they must be 99s) . I called AGR who made my rack and they said 94+ tie rods (inner and outer ) will fit so we'll see in a few days .
2003 Mach 1 Springs
Quote from: 2tbirds;363099
ricktjr... Can I see a picture of the front before you take them out ?
Are you useing Isolators ?
Also, I think its wise to say if the car is just sitting around it will be about 1/4 higher than when you drive the car for a week or so.
I had a friend swap SN95 springs and cut the front one coil. It looked even for a week in his drive way (without driving it).  Then he drove the car for a week straight and it settled down 1/4"
Is your car a V8 or what?
Just in case. If you decide to get rid of the rears I'll be waitting :)  I got dibs on the Coil Spring Specialties or the Mach 1s
Call me 267-625 6054 about the springs I'm not using when you get a chance .
2003 Mach 1 Springs
Reply #39
I DO know fox outer rod ends won't work with SN95 inners, or the other way around....no idea if SN95 inner rods will fit a Fox rack.
2003 Mach 1 Springs
Reply #40
Turns out the sn95  inner and outer tie rods fit the fox rack and the length is just what I needed .
2003 Mach 1 Springs
Reply #41
Quote from: ricktjr;365901
I already got mine lowered. I used Steeda Sport front spring (1.25" drop) and stock 94-04 Mustang rears. Its totally low as can be. However, I'm considering converting to coil overs on the rear  so I can bump up the rate and play with the ride height.
I need rear shocks and since Bilsteins are $120 or so a piece, if you buy from Maximum Motorsport the coil over kit is only about $70 more on top of that. So, thats probably what I'm gonna do. Thanks anyway.
Heres my car with the current set up I listed above.
XX
