Topic: I am doing it again...final pics... (Read 3761 times) previous topic - next topic
I'm running to the "Zone" to get some gaskets and anti-freeze shortly when they open, then, time to replace parts that aren't broken.
nice.....
That looks awesome. I like it a lot better without the "Trick Flow" script.
Me too. Plus, I've seen a LOT of Stangs with Trick Flow intakes, and I didn't want mine to be "One of very many". It's installed and running. The t-body is whistling. I have to figure out how to stop that. I think a small hole in the blade is the trick, but I'll gather info first. I also had the mildly modify the coupler that connects and seals the pipe to the throttle body for the CAI. The 70mm t-body is larger..........apparently, . I may test it with the 65 and see if I like it better. If so, I'll swap back to the 65mm t-body and let it be. Pics and news later.
