Topic: 50tbrd88's T5 swap thread (Read 10834 times) previous topic - next topic
Yes, I hate having to take an hour or two to make a parts run.  Wrestling the exhaust all back into place was a real bear as well...a lift would have helped things a bunch.
I hope we make good progress tonight!
If you change the tranny fluid go to the Mobil 1 Synthetic ATF.  I have used it in the T-5 in my Coupe for over 10 years and I beat on that car quite a bit and have had zero issues relative to the fluid.  Had it rebuilt about five years ago but I bought it used so who knows how many miles it had on it then.  It was just normal wear and tear as far as the builder could tell.
Some may frown on this but I use two quarts of the Mobil 1 synthetic ATF and one quart of the Mobil 1 synthetic rear gear oil.  Its just a personal preference and from what we can see (a couple of my buddies run this as well) the transmissions have held up better over time.
Darren
Quote from: Aerocoupe;360097
Darren
I already put conventional ATF in it, but will keep that in mind when I change it.  That's interesting...I have a T-5 tech manual and I'm fairly certain it says to not use synthetic.  Sounds like that's incorrect though if you ran it that long without problems.
I also use the factory suggested ATF. No issues at all. The Sport is really fun to drive with the 5 speed. You'll love it.
I read that you had already filled it with the factory suggest ATF but was just giving an alternative.  If you search around you will find that Mobil 1 has been approved by Tremec and several builders are using the Amsoil synthetic.  These both are compatable with the blockers in the T-5.  The tech manual you have is current but has not been updated in years and the synthetics have evolved since then.  Some people swear by the Mobil 1 and others by the Amsoil but again there is absolutely nothing wrong with the regular ATF.
Darren
I have driven the car with the T5!!!  There is a little problem with the clutch pedal adjustment, however.  I pulled upwards on the clutch pedal so that the quadrant is in the "notch" furthest forward but the only engagement I get on the clutch is literally all the way on the floor.
Is there any other way to adjust it?  Surely there is a way to get the quadrant to ratchet further forward and pull more cable.
Other than the pedal adjustment, the car drives GREAT.  Runs smooth down the road with no shimmy's, shakes, or other drama.  The used transmission I bought seems to be in great shape with no odd noises or anything.  I am still not sure if my speedo is correct...it seems to be reading high.  I counted the teeth on the speedo drive gear and there appear to by 7, I am running the red 21 tooth (?) speedo gear.  by everything I've read this should be optimum with the 3.73's I am running.  Minor detail...
double post
I'll go Mobil 1 when I swap the fluid in the tranny next time. I run Mobil 1 fluids in the engine and differential as well.
Doing a little research today on my clutch adjustment problem.  I found this article on corral: http://www.corral.net/tech/drivetrain/clutcha.htm
Have you guys ever attempted "method 2" the article discusses?  Anyone think this will help me?
I have an aftermarket billet quadrant and an adjustable cable. I have the original parts in a bag in my tool box.
So will I have to go aftermarket on the cable or are were there factory adjustable ones available?  From what I've read the Ford clutch cables are the best out there.
Jeez I bet it will be a pain to change that quadrant with the pedals in the car.  Wish I would have just got one and installed it while I had everything out.
If you have an aftermarket quadrant, you need a firewall adjuster (mine wouldn't fit with the big factor brake booster) and/or an adjustable cable. My cable without a firewall adjuster has been fine. The firewall adjuster makes it easy to adjust from under the hood instead of under the car. It only takes a few minutes to adjust under the car (Practice I suppose).
Quadrant change in the car sucks but it can be done.  I cut mine up with a pneumatic saw and then it was not problem.  The saw fit up in the work space and I just hacked the stocker down until it was manageable.
http://www.sears.com/shc/s/p_10153_12605_SP100A1798S1705453203P?prdNo=22&blockNo=72&blockType=G72
The aluminum quadrant installs with no issues as it is not as bulky as the stock POS.  I have both the firewall adjuster and adjustable cable on both of my cars but I am running the SN95 boosters so the firewall adjuster is not an issue.  I have not had an adjustable cable break and ran the same one on my Coupe for 8 years.  Replaced it due to the sheath being in bad shape from chaffing on the stock K-Member so I replaced it when I put the MM tubular unit in a few years ago.  I run the adjustable clutch cables from Steeda:
http://www.latemodelrestoration.com/item/ST-1720000/82-95-Mustang-Steeda-Adjustable-Clutch-Cable
Darren
I am curious what happened on the clutch lock out wiring?
Quote from: flylear45;360194
Oops I forgot to mention that.  I ended up just jumpering the safety switch and going without it.  ;)
I did get my clutch pedal adjustment lined out tonight.  I used the "method 2" mentioned in that corral link I posted earlier.  I just pushed up on that tab until it clicked once and now my clutch pedal grabs several inches off the floorboard.  I drove the car about 20 miles and so far so good!  Eventually I plan to upgrade to an adjustable cable and new quadrant.
The only thing I need to finish up is to find a way to attach the shifter trim .  The tabs that hold it down on the front section are broken so I'm afraid I may have to use silicone or something to get me by until I get a new bezel.  I also am going to try and put in the 23-tooth speedo gear I had in my AOD to see if it gets my speedo closer to being correct.
