Topic: Impossible to start when warm and stalled. (Read 3468 times) previous topic - next topic
the idle in park is  again until warmed up but just recently started fluctuating while in park after warmed up....the fluctuations are accompanied by hissing from the smog pump check valve.  On my next day off I'm checking the codes myself with a  test light.
Quote from: mcb82gt;359761
You have to get your timing set properly before you do anything else.  You cant just eyeball it.
