Topic: NEW 5.0L Explorer motor (Read 14057 times) previous topic - next topic
Reply #45
Quote from: Gdub;375090
Ok Vinnietbird, thanks for the heads up. The plan is to have the engine compartment as slick as possible so I will be using custom made stainless hoses for the A/C and fuel and since I don't have any of the Fox stuff I will give it a try and see what happens. Do you know anyone that has used the Explorer accessories?
I am.
Reply #46
If your using the explorer parts, the pulleys are closer then a fox setup. So you either need to change waterpump/timing chain cover and the crank pulley to fox, or run the differently spaced explorer stuff.
Reply #47
Quote from: flylear45;375196
I am.
Flylear, did you have any issues with the explorer stuff?
Reply #48
Need to re-wire for starter
Steering pump is higher than reservoir. ( Mount new reservoir above pump center line)
Steering lines don't match up.  (Make new lines or splice hard line with 2,000 psi connector)
Alternator wired differently (same as 3g swap)
Won't clear TC scoop plastic.  (remove plastic)
Steel heater lines won't work. (need mustang or 5.0 bird ones)
AC lines will need to be custom made
That's off the top of my head. If I think of anything else I'll let you know.
Reply #49
Thanks FlyLear45, I will keep these things in mind. If you think of more let me know please.
