Topic: need some help with finding where things go. (Read 1720 times) previous topic - next topic
i put the motor back in my car and now i have a bunch of wires that im not sure where they go.  i removed the a/c for now so im sure that is some of it.  im going to upload some pics, can someone write on the pics where that plug or wire goes and re upload them?  it would help a bunch all i have is the hayes manual and its not much help.
thanks for any help
84 TC - under contruction
2018 F150 2.7 4x4 STX
98 F-150 XLT - 4.6, auto, 4x4, extended cab
Ok the 1st pic would be better to see the wire colors on the two wire plug. Looks like the ECT or IAT plug. the sinlge wire not sure at the moment. The 2nd pic that big plug is the plug you hook the scanner into to check for codes should be a single wire square type plug that goes with it. The 3rd pic I do believe those are the plugs that hook the motor harness to the car. It has been some time since I've been in there.  In the 4th pic at the moment all I can is I do believe the yellow wire is for the hood light. Not sure at the moment and its to late to go out and check at the time.
hope this helps
Stuckman
also in that 4th pic that square plug with the red and black wires I do believe is the IAC plug.
Stuckman
thanks i really was wondering about that big one in the second pic i did not remember unhooking that from anything.
