Topic: performance parts (Read 4601 times) previous topic - next topic
performance parts
I am having trouble finding any kind of proformance parts for the 87 3.8 v6 in my cougar. If anyone has any suggestions on sites where I can find some it would be awesome.
performance parts
Your best source (indeed, your only source) for performance parts for your Cougar is an 87-93 5.0 Mustang donor car. There is virtually zero aftermarket support for the CFI 3.8, so an engine swap is pretty much your only option...
performance parts
Basically it's:
Step 1: remove CFI 3.8
Step 2: install better engine of your choice
performance parts
Remove the CFI, I beleave a holly two barrel carb will bolt to the stock intake. Comp cams make performance cam for 3.8s and you can put newer mustang tubuler manifolds and dual exhaust. Or like everyone else has said, drop a v8 in. 302s and 351s have the same bellhousing as the 3.8 so just buy some v8 mounts and drop her in.
performance parts
Quote from: Bruce M;359060
^^^THIS, and TURBO. (low boost though) stock engine cannot handle more than 8psi MAX. Short of boost, though, yes - engine swap is your only real source for higher torque. Unfortunately.
performance parts
Quote from: 87cougar;359075
And here is the place I got my roller rocker arms from, they're good and really easy to install.  They say you get about 18HP and 20lbs of torque from the 1:8:1 ratio.
http://www.harlandsharp.com/ford_v6_v8.htm
Hooooly Geezus you paid almost $400 for a set of roller rockers????
performance parts
does anyone have more info about switching out my 3.8 v6 for a 302 or 351? And what of 302 or 351 i can or should use?
performance parts
334 bucks.  Yeah I know it was a bit much.  But you cant find them anywhere else for cheaper.
performance parts
Yeah but you can buy 302 rockers and they work the same. And they're about 200 bucks cheaper. You just wind up with 4 extra rockers afterwards...;)
performance parts
Quote from: bigslim2454;359100
right here: http://www.coolcats.net/tech/advanced/ho_transplant.html
performance parts
But are they 1:8:1 ratio?
performance parts
you can get 302 rockers in just about any ratio you can dream of
performance parts
Builds are based on your budget and what you will use the car for.  Check my Car Domain for some V-6 ideas.
performance parts
Quote from: Chris1987LX;359495
And then head on over to mine!
