Topic: I need help on a decision!!!!! (Read 6845 times) previous topic - next topic
I like the stock lights much better. Something just bugs me about the other ones. To get an unbiased opinion I asked my wife who just got out of the shower and didn't see any of the topic other than the pics I showed her which she likes more and she likes the stock ones too and said "The other lights look weird".
'86 Turbo Thundercat (Cougarbird)
'02 TrailBlazer LT 4x4
'08 Chevy Cobalt
Ditch them...
I like the stock ones like a bazillion times better.  ;)
I don't like them.  Also, headlights are designed so you can see at night.  If they aren't even bright, why mess with them.  If I were swapping headlights, I would go for some e-code headlamps, for any given wattage, they are brighter than USDOT headlamps, they are safer, they produce less glare, and unless you have inspections, no one will know you are not running a DOT approved lamp.  You should be able to find e-code lamps easily enough for your car.
ok, I guess these are not cool enough for you guys.:mullet:  I will be ordering these as soon as I get some money to pay for them!!:punchballs:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trksid=p5197.c0.m619&item=250797050676&viewitem=&category=33710
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
These are the ones I bought.
http://cgi.ebay.com/ebaymotors/82-92-84-88-CHEVY-CAMARO-4X6-DIAMOND-CUT-HEADLIGHTS-H4-/300485672941?pt=Motors_Car_Truck_Parts_Accessories&hash=item45f6577fed#shId
You will probably need to get another set of plugs for the inners because I think thats what my problem is with them.
Now you're talking. The other ones are not good. I like these and can tell they would look nice on the car.
Not a fan of aftermarket projectors, especially if you're giving up the functionality of the stockers.
'83 302/AOD Heritage (silver/red, full restoration w/ SEFI, 5-lug, 8.8, rear discs in-progress)
'95 Explorer Limited (white/gray, 4x2, 323K mile daily driver)
'97 Cobra (black/black, bolt-ons, 4.10's)
'04 Lightning (black/gray, bolt-ons, stock-pulley gas guzzler)
heres what they look like on mine.
Quote from: fordguy545;358929
Thats it im getting them!!!!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
forgot to mention I had to grind a bunch out of the buckets to get them to go in with that giant rubber thing on the back, but you may have already dealt with that.
yep, but only did the drivers side, will do the other when I get them in. Did you ever fix the wiring from the 2 pr0ng to the 3 pr0ng???
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
They don't look as good as stock. Stock has classs. Look like something a kid would put on his Honduh.
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
I like em. The first set is  but these are nice.
OMG, I might have to have this thread locked!!! lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
