Topic: Stuck at work (Read 2789 times) previous topic - next topic
Stuck at work
I'm desperate, I have an 88 Sport Coupe that won't start. Turns over fine. The fuel pump relay is humming (thought it was my blower fan) and the car never starts. Replaced the relay thinking it was an easy fix but no joy. Car is totally stock, any suggestions on what could have given out.
Car started fine this morning.
Stuck at work
Does it have spark ?
Stuck at work
Have no real tools with me, how can I check for spark?
PS No inertia switch, removed that 10 years ago. Can't hear the pump over the relay noise.
Stuck at work
if you have screwdriver or similar  . remove a plug wire stick the screwdriver in the wire and lay the screw driver on something metal DONT HOLD ON TO IT  crank the engine and spark will jump from the screwdriver to ground .
Stuck at work
Got spark now what?  What would cause a brand new fuel pump relay to make noise like a blower motor?
Stuck at work
Is this the black square relay under the hood making noise? Or the pump in the tank?  If a relay is continuously clicking, then it isn't getting a solid power signal.
Real relays shouldn't hum.
Stuck at work
I had the fuel pump relay buzz like that when I was having grounding issues.
Stuck at work
Quote from: Loaded87IROC;358120
See? Bad signal power to the relay. Use some jumper wires to the battery from the small wires on the relay and head home. Don't forget to unhook them though!
Stuck at work
Where does the power come from normally, the ignition switch?
Stuck at work
Hmm...Should. I think Jcassity has an EVTM posted online somewhere...Hold please.
Stuck at work
Well, here's the EVTM:
http://s47.photobucket.com/albums/f162/jcassity_bucket/?start=all
Unfortunately, I have no idea which picture holds the info you want. The power either comes out of the ECM or the switch. I would just look for a way to piggyback in right next to the relay though.
Stuck at work
Do you have a constant snapping spark as it's cranking, or do you just have one spark at the end of the cranking? The former is correct, the latter is incorrect. One spark at the end of cranking means one of several things, bad pickup coil, bad ignition module, or a bad ecm relay (don't remember if this one applies to our cars or not, but once I had a bronco with this issue).
You could also have a worn timing chain if the car has high miles. I had a 3.8 that slipped the chain and wouldn't start with proper spark and fuel.
I have heard that a blocked catalytic converter can cause a no-start too, but I never experienced that one.
CoogarXR : 1985 Cougar XR-7
