Topic: 1985 Cougar for Sale (Read 1306 times) previous topic - next topic
Car located in Gleason, Wisconsin. Asking $1600. Many throw in's and modifications. E-mail me at two_tone_5pt0@yahoo.com and I will supply a specs list. The "0" in the e-mail address is a zero.
Thanks,
Jason
please describe through ins and moditications?  what motor/trans/rear end are in the car?
84 TC - under contruction
2018 F150 2.7 4x4 STX
98 F-150 XLT - 4.6, auto, 4x4, extended cab
1985 mercury cougar specs
engine:
*302 bored over 0.030” / professionally rebuilt w/-0- miles.
*new 650 cfm carter carb w/weiand stealth aluminum intake
*rebuilt heads
*custom cut roller camshaft/ new roller lifters ( berry cam service of lester prairie, mn) spec available
*roller rockers/needle bearings
*domed pistons/mid-to-high compression
*new stall torque converter
*new distrubutor, cap and wires
*new msd ignition
*new shorty headers
*dual intake air cleaner
*rebuilt alternator
*serpentine conversation
*new motorcraft battery
*new 3 core radiator
*new starter relay and cables
*new electric fuel pump and mount
factory cruise retro-fit for operation with carb
thanks for the interest,
jason
transmission:
*aod non-electronic
*professional rebuild
*shift kit upgrade
*dyno tested
*double hump rear support for dual exhaust
*air conditioning core converted to transmission cooler
included:
*extra set aluminum directional rims custom painted to match car (no tires) + aluminum rims pictured on car
*new floor shifter (b&m)
*new 3” cowl hood/ fiberglass/ primed for painting
This is being sold with intention for parts car. If you study the picture there is a rust hole under the left side door. The amount of investment in accessories determines the value.
Why the 0 miles?
The motor that was in the car, when I purchased it in 1997, was a used engine with undisclosed miles (302CID). A valve spring broke, dropped a valve into the piston and sped the motor. This current motor is the beefed replacement which has never been run-in. Be advised, I will pull the intake and a head for a serious buyer who supplies replacement OEM gaskets.
Man... I want that cowl hood!
John
Me too, But I'm silly broke right now. ;)
HCOR,
    I'll keep you on the plate in case I strip it for salvage. I'm likely to go "swap meet" on the powertrain when this summer's car shows come and send the body in with the soup cans.
What is so special about that hood? I have two that look like it? Sorry for dumb question. Inform me please
anything new for half price gets attention. I'm asking %50 return on any of the new items listed.
This Car has been stripped for parts, make an offer.
