Topic: You need subframe connectors (Read 17686 times) previous topic - next topic
Reply #45
Thanks for those pics of Daminc's subframe/jacking rails Strokerbird, but I was trying to stay away from having to cut the floor the way Daminc had to.  I'm just planning on installing full-length subframes made out of the same 1" by 2" box tubing a lot of people here used to make theirs.  I'm not a chassis expert, so I thought it would be a good idea to ask if the 1/8" wall box tubing I found would be strong enough.  I'm planning on using seat brackets and gusset plates to help hold the box tubing to the subframes after the tubing has been welded to the subframes.
William
Reply #46
i'll see if i have any.. i didn't have a camera at the time. or a phone with a camera that was worth a , for that matter.. the only pics i really have are 1's my buddy took during the build
Reply #47
I didn't mean to repost his pics lol. Still trying to figure out the forum. But I'm really wanting to stiffen up the car for cornering and fun driving since the only "dragstrip" we have in my area is an 1/8th mile and it's a bit of a waste of time. I like when I can make a car handle like it's on rails.
Reply #48
I'll tell you what Stroker, if you REALLY want to lock your car up, you should think about installing frame connectors above the sub frames.  Darren (Aerocoupe) sent me some info on how to install them.  If I had the means to do it right now, I would, but I'm getting hammered with bills.
William
Reply #49
Quote from: StrokerBird;376909
DAMINC you wouldn't happen to have measurements on your subframe connectors? I'd like to put a set together since I'm 6' and well over large and could really enjoy stiffening up my bird.
  There's a wrong measurement in the last diag brace spacing in this version, i think.... but you get the idea
Reply #50
Quote from: 88 Blackbird 5.0;376938
you talking about 'through the floor' connectors?
Reply #51
No.  These go on top of your subframes.  I had never seen anything like it before.  It's supposed to be a lot stronger than just installing subframe connectors.
William
Reply #52
interesting.. i'd like to read about such things
Reply #53
In a nutshell, you cut the floor above the subframes and install box tubes that connect the subframes from the top.  When you've welded everything up and are done, you'll have a protrusion from the box tube that runs the length of the driver's footwell and the passenger side footwell.  That's the only drawback to this mod I canthink of.
William
Reply #54
yeah, those are 'through the floor' subframe connectors lol
Reply #55
Daminc's subframe connectors are through the floors, but they're under the subframes.  I though what he did was considered to be a traditional through the floor set up.
William
Reply #56
what i consider 'through the floor' is anything going in from the topside, instead of underneath.. jerry's look like semi-typical connectors with the not-so-typical jacking rail supports.. i may steal a bit of his setup (sorry jerry :p ) for my capri, to make it a little more sturdy, before i take it for it's chassis certification.. i have yet to touch the jacking rail part of it
Reply #57
Isn't that something?  Learn something every day.  So those ARE what guys are talking about when they mention "through the floors.". The nice thing about them, is that you can install them AFTER installing normal SFC's.  Unlike Mustangs, I think our cars can use a single, straight box tube with no bends, or welds in the middle.  It doesn't get stronger, or simpler than that.
William
Reply #58
mine are half through.... although, I did cut the floor open in the front, to weld the inside of the 2x2 to the frame too. I didn't think just welding the outside was enough.... lol
Reply #59
Quote from: 88 Blackbird 5.0;376980
mine are half inside the front subframes. I cut them and slid them in
