Topic: Interior work (Read 1860 times) previous topic - next topic
Interior work
Over the winter I did some repair work on my interior. I had a rug on the dash because California sunshine dried it out. I ended up using a dash cap to "restore" the dash top. I spent about 4-5 hours tpuppies the thing so it fit just right. I think it looks good.
I also had a panel replaced on the lower rear seat cushion. It had a small tear on the passenger side.
This is just a oooo shiny picture. I polished and waxed the car about a week ago, the last time it was out of the garage and it's first trip out since October.
Interior work
How nice.  Great looking ride.
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
Interior work
Looks good, did you order a painted dash cap or did you paint it yourself? Also who did you order it from? I've been looking at them and have seen a couple different places but not sure if they are all the same or not.
Interior work
Looks great. Those caps need a lot of tpuppies, but in the end, they look great. Especially compared to a cracked dash.
Interior work
Very nice work.  Your car looks great.
Mike
Interior work
Quote from: Dansbirds;356666
I ordered it from dashtops.com. I ordered it painted in graphite. It is a  close match for the dark gray that the dash top originally was. I had to do a lot of tpuppies around the speaker grills and defroster vents with a Dremel and a sanding drum to get it to fit correctly. I also had to do a bit of tpuppies to the back where it met the windshield. It took 4 hours to trim because I would remove a little material and then test fit it before moving on.
Interior work
Quote from: thunderjet302;356682
Sounds tedious as hell but looks great. Well worth the effort over a cracked/horrible dash IMHO
FOXLESS!!
1994 Lincoln Mark VIII
Interior work
I did the same thing...it is VERY tedious, but, once you're done, it looks a LOT better. Also, if you don't have patience, don't do it. Once you remove too much plastic, it's too late. When you have a cracked dash, even if the rest of the car is great, it's still a dark cloud hanging over the car. Once the cap is on (or a replacement dash is installed), you get a whole new feeling about the car.....at least I did.
Interior work
Looks great , what holds the cap on the dash ?
Interior work
Mine has a couple small cracks, but there is so much more I want to do on the drivetrain first.  Need..... More.....Power.....
Mike
Interior work
Quote from: mcb82gt;356721
I need more power too. I just want the car to look nice before I add more power ;).
Interior work
Quote from: hypostang;356689
It comes with an adhesive that "glues" it to the current dash. You may have to trim down any high areas on the dash like cracks that are raised,or whatever. Once it's all flat, adhere the cap.It's cheaper to buy it in natural black and dye it yourself....easy to do. If the funds allow, you can buy it already in color. I would adhere the cap, with the dash out of the car, then dye the whole dash and glove box lid to match (or two tone it if you like). I took my dash from an '86 with no cracks (Taupe in color), prepped it, and dyed it gray. Turned out great.
Interior work
Mine was two tone to begin. I like the factory dark gray on top and light gray on the bottom.
