Topic: Door Lock actuator (Read 1949 times) previous topic - next topic
Door Lock actuator
I have a used one coming from a member here.  Finding parts for these cars is always a trip!
Door Lock actuator
Quote from: 347Thunder;356914
I bought that kit and it is a piece of !!! they are so tight I almost bend my key and I have to push the lock down while hitting the lock button, do not buy for a t-bird I finally took them out
I would have sent them back then.  Never had an issue like that with mine.....
Door Lock actuator
That was dumb of me, I thought because they were for a stang that is why they didn't work
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Door Lock actuator
Sounds as if they were binding from the get go.  It's funny.  Here's what I've been through.
My passenger door actuator is the original to the car.  The original driver side took a  about 5 years ago.  I ordered a replacement from the dealer.  It lasted 9 months and the motor burned out.  $135 down the drain.  I then found the LMR ones.  First one lasted a while before some moisture got down into the rod and froze it up.  I think this was from leaving the window cracked by mistake one night while it rained.  Second one is currently on car.  I made sure and greased the rod before install.  So far, so good.
Door Lock actuator
yeah these were so tight I couldnt even pull these in and out, chinese !!!!lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
