Topic: fuel line clamp back thingy (Read 2587 times) previous topic - next topic
How does this part come off?
We found a temporary repair on the fuel line coming out of the filter going under this clamp thing and the line had some rubber tape on it.
I made the repair but would like to remove the clamp to dress it back under.  Otherwise, I will leave it zip tied to the group if i need to.  Apparently, it had been leaking for a while and finally gave out last night leaving my son stranded in just the perfect spot,, in our driveway about 1200 feet down the drive.  Imagine how stumped i was when i had spark and smelled fuel but the shrader valve wouldnt spit out a drop.  Oh, it was dark as hell and no light other than an under the hood bulb.  We pulled it up to the shop and fixed it today.
what i difference fuel pressure makes,,lol.  this repair made the slugish feeling go away along with some of the ticking noise.  Im now wondering if code 34 has gone bye bye.
This car is in excellent shape!
OMG code 34! I have one too. I has to do with the EVP sensor. Keep me posted on it!
How do I subscribe? I think you should drop everything right now, even if you are at work, like me, and go test for code 34. haha. Obviously I'm joking, but I am interested in your findings.
edit** Figured out how to subscribe.
well, we shall find out soon,,,,
egr held vac
 i am curious if it was fuel delivery related since i know the psi was low due to the break in the line.
now wouldnt that figure!
I took mine off years ago. it just keeps the line attached to the car
You have to drill out the steel rivets.  Not an easy task without destroying the plastic holder.  Once you drill them out, I guess you'd have to drill through the floor pan and re-attach with screws or small bolts.  Of course, you'd have to pull up the carpet and insulation to attach bolts.
I'd suggest you thread the new plastic fuel line through the holder before re-attaching to the ends - and NOT take the holder off.
Quote from: jcassity;354786
egr held vac
Isn't code 34 related to the EVP? How is the EVP related to fuel? I have an on demand code 34 too. I've been trying to trace a short of some sort for a week, with the help of Joel over at SBF. I think it may come back to that pesky orange wire on the back of the intake that some people ground, others don't.
JCassity, can you look and see if you have an orange wire with no end on it on your bird?  It comes out of the bottom of the white ten pin connector on the intake.
mine rotted off...lol
yeah,, welp,, splice installed and not worried about it going back under the clamp now that its been described how the platic retainer comes off.
Quote from: jcassity;354831
So, still a code 34, or no? lol
not home now,, will chase 34 later.
It seems code 34 and us get along well so we may make friends.
Cassity, it'd rather be your friend and get rid of the  code. I think thats called having your cake, and eating it too, lol.
So... did the fixing of the fuel leak fix the code 34?
