Topic: Blue by You - TC+4 (Read 47259 times) previous topic - next topic
Blue by You - TC+4
Great looking engine so far. Reminds me of the Sport's when I had it on the stand last year.
What valve covers are you going to use?
What size throttle body and spacer?
What cam is in it?
I've sen some Cobra plaques on Ebay from time to time for a reasonable price. I like the Cobra intakes. I am working on a polished Explorer right now. Keep up the great work. I'll be looking forward to more pics and info.
Blue by You - TC+4
Quote from: vinnietbird;355968
What cam is in it?
Hey Vinnie.  Our engines will be similar.  I'm running the stock HO cam for a smooth idle and low-end torque.  Plus the overlap is very boost friendly.
I do have a replacement Cobra plaque.  I may do a little more cleanup on the upper intake before putting in on though - there are a couple of dirt spots to be cleaned up.
The throttle body will probably be a 65-70mm unit.  I still need to buy one.  No spacer needed on the Cobra intake.
I plan to use the stock HO aluminum valve covers in black wrinkle paint.
I hope to get the oil pan and valve covers painted this week.  Then on to the front accessories...
Blue by You - TC+4
A little more progress...  Got the valve covers and oil pan painted and installed along with the water pump, coolant pipes and injectors/Explorer fuel rails.
Blue by You - TC+4
Can you guys tell me what your engine has in the oil galley hole here...
I suppose it is pipe threaded and I can just install a plug?
Blue by You - TC+4
It's not a real "hole".Leave it alone. Great looking engine. I am surprised you didn't match the oil pan to the block,though. Either way, nice and clean..
Blue by You - TC+4
What are the plugs on the side of the oil pan for ? is a turbo in the future?
Blue by You - TC+4
Quote from: thewestie;356971
Yep. Turbo is in the future.  That is an AN-10 drain fitting. :evilgrin:
Blue by You - TC+4
Nice I wish Id thought of that during my build
Blue by You - TC+4
Wow that is pretty
Blue by You - TC+4
Reply #39
Diggin' the crinkle finish on the valve covers.  What was used for that?
Blue by You - TC+4
Reply #40
Thanks for the comments guys.  It is coming together nicely.  My family is out of town in a couple weeks, so I hope to have a lot of dedicated time to pull the existing drivetrain, clean up the engine bay and get this engine into place.
Quote from: V8Demon;356996
Regular old VHT Wrinkle Finish paint...
http://www.amazon.com/VHT-Wrinkle-Black-Spray-Coating/dp/B0028ZPRA8
Blue by You - TC+4
Reply #41
Those valve covers do look really good.  I'll be stealing that idea lol.
Blue by You - TC+4
Reply #42
Well, I've been really thrashing it the last couple days.  Here is some progress...
Blue by You - TC+4
Reply #43
Getting closer by the day. It'll feel great to hear it run for the first time when you turn the key.
Blue by You - TC+4
Reply #44
Careful with those ratchet straps.  I've had one break on me (the buckle, not the strap).  I'd hate to see you loose a finger.  Awesome build man.
