Topic: 30% off at the junkyard this weekend...any requests? (Read 4278 times) previous topic - next topic
Quote from: 88turbo;353554
Jerry are you needing the chrome lines that come up the front of the engine? If so I might have them :D
Thanks, I got those. Just need the ones on the frame
These, minus the splices.
Oh man Jerry it might be time to just make them yourself lol.
If those are the same lines for the v6, which logically they should be, then I will see if I can get them when I go back out. There's only a v6 car and a tc in the yard.
If I get them used, they have to be rustfree.....My last choice is going straight vinyl, and deleting the hard lines on the frame. I really don't want to make them and try to connect them to the vinyl lines on each end. If I go with making them, then I will use stainless front to back.
Ooooh, shiny. Stainless;)
I'll let you know if I come across any.
Ok
The lines are different in regards to V8 vs V6, at least as far as where they enter the engine bay..the 3.8 lines come through the round hole, while the V8 lines come from under the passenger side of the wheelwell. This is on '88 cars, I expect the '87 V8 to be the same, but the '87 V6 will probably be different because of the CFI system...
Jerry, there's an '88 V8 Cougar (actually, there's 2) at the pick n pull...I am going to try to make it back there this coming sunday...if so, I'll look at those lines for you.
Those lines usually fare pretty good up here, if you can't find any.
ok, Vinnie said he's looking on Wed. if he doesn't find any, you guys are up next, and I'll start a new thread for it in the wanted section.
I'm gonna look anyway, since I might need a full set of V8 lines myself...if they're not too bad on price, I'll grab the others as well.
Ya never know, I've had two Birds in flames...
I need a Mark8 E-Fan also. ;)
Quote from: Romeo2k;353710
Get a Taurus fan. They flow as well, and are VERY plentiful and cheap at any yard.
I look for the mark fan every time I go, they are always pinched long before I get there.  They have TONS of 3.8 and 3.0 Taurus fans though.
My Taurus fans cools great....probably a little too good.LOL. The needle never makes it above 1/3 of the gauge.....even when it hit 117 degrees.
will a fan out of a grand prix work? I got one of those
