Topic: Mustang Shorty Headers? (Read 1317 times) previous topic - next topic
Any chance that 5.0L Mustang Shorty Headers would fit my '83 5.0L T-Bird?
Or if anybody can explain any mods that I would have to make in order to make them work, that would be appreciated.
They should bolt right on to the engine , you will have to use a mustang H or X pipe though,
 Sometimes there has to be slight modification to column shifter linkage , but that entirely depends on each car as each one is unique
I went out o my way to drill out the lower stud on the drivers side header to the h pipe because of the linkage, but it would have been 100x easier to just unbolt the linkage for two minutes while I bolted the h pipe on.
They will work. Just take your time, and if you hit a snag, take a clear pic of the interference and post it here. Someone has overcome whatever you run into. Dont try to rush it.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
