Topic: Rubber on lower portion of coils (Read 2061 times) previous topic - next topic
In my feeble attempt to install new bushings on the front lower control arms I ran into a snag. When removing the old coil(s) the driver side coil was broken. I will assume it has been broken for some time due to the amount of rust in-between the breaking points. The break point happened on the lower potion incased in rubber.
Onto the question. I ordered new front coils and the new coils do not have a rubber casing on the lower portion of the coil (portion that seat on top of the control arm). Is this rubber "optional"?
Those rubber pads are NVH reducers, so they're nice to have but not necessary.  They do affect ride height so if you remove one, remove the other side as well.
__________________
Twin '85 TCs
White/ Grey 2-tone
They reduce noise. A company named, um, I can't remember, make them. They aren't too expensive.
I think energy suspension makes new coil isolators. You want them other wise your car will squeak like crazy.
I've been known to make 'em out of sections of garden hose...
Thanks for the help. I found a set on a mustange website, has the lower lube you slip on and the upper.
Yes, energy suspension is the name I couldn't think of. I bought a set, they were bright red and work just fine. They were cheap too, like $15.
Maximum Motorsports also makes them but  they are not rubber like the factory.  I had a set on my Coupe for eight years and when I pulled the H&R Super Sports off to go coil over they were still in good shape so they were sold with the H&R's.  MM also makes the rear spring isolators.
Darren
Quote from: thunderjet302;351944
 Yes they do.....
Looks like daminic and I's broke in the same spot. For sec there I was thinking, I don't recall posting a pic of this.
I wonder why so many T Bird coil springs break.  I must've read about ten or more broken front springs on this forum.  Mine were broken too.
Mine were broken too, but not in the place they usually break:
XX
I dont have any pics , but my SVO  had broke the right front spring too
