Topic: Needed ASAP... 87-88 V8 sport gauge cluster. (Read 953 times) previous topic - next topic
Need a V8 sport gauge cluster ASAP, for sons car.  Had ignition short out and fried coupel fusible links and mess up plastic cicut board on cluster.  Got car runnign and runs fine, but not sure AMP gauge is working, so want to replace it..  Send pics and info to droptop93@att.net
88 T-Bird Sport-- H.O conversion, GT40 heads, FMS 1.6 RR's, Cobra/EXP intake, 65mm TB, MAC headers, X-pipe, 05GT lers, TC 8.8 with 3.73's.
Quote from: 1Bad88tbird;351860
you have an email.
replied
Are the sport speedo gauges on the sports cable or electrical ?
Quote from: thewestie;351979
Electric
to bad wanted  a cable one
Steve, you may have to go aftermarket. I think all the 86-88's have electronic speedo's.
Yea I bought one just trying to avoid hacking the cluster i cant afford a complete set right now.
I have a speedo out of an 80's stang. Not sure if it would work, but I would let it go cheap.
Quote from: thewestie;352120
Why would you hack the cluster? To try to use the buttstuffog other gauges? Will that even work?
I need to mount a cable driven speedo in the cluster witch as far as i can see means a hole saw through the panel and who knows what contacts Ill break and what instruments Ill lose. I have a 80s mustang 140 speedo but doubt that will work I have a sn95 dash but not sure what drives that speedo
What tranny are you running? Reason I'm asking is that the electric speedos just need the two wires connected from the sending unit on the trans. You should be able to use the Sport cluster without problems.
I running a T5 but I pretty much gutted the wires in the car, can I run new ones. I'd love to keep the T.C cluster. Id imagine Id need to re power it? The other day some one left the map lite on and drained the battery. When I had the jump pack on and was cranking it over the speedo jumped to 30 mph then dropped to 0. hasn't moved since?
:confused:
http://calgary.kijiji.ca/c-cars-vehicles-auto-parts-tires-other-parts-accessories-1987-88-Ford-Thunderbird-Mercury-Cougar-V8-Sport-Cluster-W0QQAdIdZ242378985
This is in Calgary Alberta Canada but it is cheap. I know the guy too. He is a member on here.
:burnout:
