Topic: Misc TC turbo tech (Read 2320 times) previous topic - next topic
Misc TC turbo tech
Are stock TC turbos internally gated? And what kind of header  do they use? Isn't it a T3?
Misc TC turbo tech
Yes and yes.
For better clarification, you need to specify what years you're talking about.  83-86TCs use a Garrett T3 turbo.  87-88TCs use a Warner-Ishi IHI turbo.  Both have the std T3 header  and both use internal wastegates.  The are different though.
Misc TC turbo tech
83-85. I'm getting one from an 85. How would you control the boost pressure? would that require an additional external boost control valve for the wastegate?
Misc TC turbo tech
The boost pressure is regulated by the waste gate and the waste gate is controlled by the boost controller
Misc TC turbo tech
Yeah thats basically what I was trying to say. Thanks :)
Misc TC turbo tech
could someone take measurements of an 87/88 intercooler and give the dimensions from the PS fender at the edge of the hood, and from the firewall down to the front?
Misc TC turbo tech
^^^Anyone? Oh, and a potentially dumb question. Can a speed density setup be boosted? My guess is no....:(
Misc TC turbo tech
you must have a mass air system of some kind to add boost.  I will get some measurements here in the next few days.
Misc TC turbo tech
What are you talking about? The chrysler turbos are all speed density and megasquirt is speed density.
Misc TC turbo tech
I was going to ask why not
