Topic: Mustang Subframe Connectors On T-bird/Cougar? (Read 11895 times) previous topic - next topic
they should have been longer i totaly agree and when i bought mine the guy had a set of mustang ones laying beside the tbird ones there idk what style stang or the brand of the conectors were but mine were like 3 inches longer i didnt ask questions i just got mine and left for all i know they could have been custom because they were blue so idk haha
If you do not want to fabricate a set I would recommend Global West's subframes.  I have them on my 83 and the fit and finish was and still is very good.  They are a full length subframe and the driver's side even has the bracket to relocate the e-brake cable.  I also used their seat reinforcement for the Fox Mustang and it worked like a champ.  The subframes on are this page (P/N 918):
http://www.globalwest.net/1980-88thunderbird.html
and the seat reinforcements are on this page (P/N 920):
http://www.globalwest.net/1979-93mustang.html
Darren
I'm so Confused I like the heavy duty ones but the lazy side of says get the global west one's. Whats the odds of twisting the car with slicks and 400 hp + 175 nitrous shot at the track withe the Global connectors?
Quote from: Aerocoupe;350757
Darren
How did you do that without modifying them?  The seat studs on the TBirds are spaced at least 2" wider than those of the Mustangs.
I wonder what the weight difference is between the Global West connectors and the custom parts by daminc (which I think are works of art BTW). Just a thought since a lot of people are worried about their weight.
2017 Subaru Outback
2007 Lincoln MKZ
1990 Ford F250 / Banks turbo diesel
Thanks for the catch Chuck.  I have them on both cars and yes the ones on the Bird are modified.  Had to think about that one for a few as the car is not in the garage.  My buddy Mike split them and welded them up to make them work.  I had to call him to see if he remembered what he did to make them work and he said it would have been about as hard to make a set as it was to modify the Mustang units.  Mike remembered installing the seat brackets before we went to the 1999 Mobil 1 World Ford Challenge.  The subframes were installed before that but I could not remember when so I had to take a trip down memory lane otherwise known as the receipt file.  I dug up the old receipt from GW and it was from 95 and the subframe connectors were $118 for the pair...I noticed they have gone up a little since then.
If you are really worried about tweaking the chassis then you should look at installing some of the upper subframes.  I have the Griggs units on my car but they can be made for a lot less than I paid and I believe there is a thread on it here somewhere.  If not here I know there are several on the Mustang websites and the only differece according to the folks at Griggs is that the T-Bird uppers are 2" longer.  I patterned everything off of the T-Bird units and made a set for my Coupe and the only thing I did different was make the upper 2" square tube 2" shorter.
Darren
