Topic: Turn signal lever demistifying (Read 8961 times) previous topic - next topic
I"ll check the build date tomorrow...I think it was a later 85 build.
Check out that cool gear selector...lol
I found an older pic, when Bear bought the car, and I see the same round one
My 86 has the square stalk
Quote from: 1986Élan;350703
Factory original?  Can you post a picture?
tbirdregistry.com
26480
27373
i would bet it is because nothing else has been changed on the column the shifte is used bad and wiggles, the wipe switch also ( i got a nos one tough without the 2 silver rings painter around the tip of it) the élan package had the 2 silver rings    as well as on the tilt lever(got that one too  nos but with the 2 silve rings painted
im thinking of buying the square style stalk that has the horn icon even if i have the horn button on the steering wheel
what do you guys think?  the one without the horn icon is super hard to find
i could take pics but i never understood how to post them here  the uploader always tells me the kb space is too high
Keep in mind it an 86 Élan that was built the 25th of septembe in 1985
Does your camera have a setting to reduce the resolution? If so try that otherwise feel free to email me the picture and I'll upload it. It sounds interesting.
I'm not sure the stalk without the horn is that hard to find, I'm thinking I have several in a parts box but would have to double check.
tbirdregistry.com
26480
27373
i was searching for nos ones  ..
i dont work tomorrow ill take a pic and email ya
I remembered there was a thread in the lead section with a link to that 85 XR7 with 10k on it.  I searched for it and looked at the pictures and it has a round lever also.
http://cgi.ebay.com/ebaymotors/Mercury-Cougar-_W0QQcmdZViewItemQQitemZ230555838841QQptZUSQ5fCarsQ5fTrucks
those are beautiful seats
Here's a slightly relevant question:
Eric stated earlier that the stalks just twist and pull out. Well, ever since I got my car, there has been no twisting, just pulling out. And it won't sit in there tight. Why won't it stay in? All the tabs seem to be intact...
rodsterh the file is too large i will need you email to send it there
Quote from: 1986Élan;350852
PM sent....but you need to clean up your INBOX, it's not being accepted.
tbirdregistry.com
26480
27373
Pretty sure they changed to the round ones when they changed the dash (85up).
And yea, They just pull out and they always seem to have a tiny bit of rust on them, heh.
I usually pull the stalk from the ones I find in the junkyard as a momento, I've got over 10 or so.
