Topic: Porosity (continuing saga with the 18984, 3.8) (Read 3644 times) previous topic - next topic
Man,, those top ends should be a dime a dozen.  Ill bet someone would ship you one free, easy to find now.
Not sure how your bone yards are your way.
I havent seen an idle control motor in so long,, my old 3.8 stood good for 330k miles and still ran except oil pres crept down to 12psi.
good luck, no intake here.
Not a lot anymore.
In fact my sister in-laws parents used to own one.
Mostly truck parts.
Long gone!
Idle Control Motor (got last one at Autozone).
Part from Mexico -- $70.00 (as I recall).
Didn't mean to exclude others with my last post.  My apologies.
David
I've got a good one on an 88 3.8, if it'll help you. I also have an idle control motor off an 88 3.8. They were fuel injected, not sure if the units are different.
jpc647
Sorry late getting back with you.
Appreciate the offer.  Not sure whether an 88 will fit the 84.
84, 3.8  was CFI not EFI or carbed.
Will try and do some checking unless someone on the forums knows??
Otherwise interested as long as no issues.
Re: Idle control, the 84 was CFI.  84 Idle control has a plunger which is moved by a small DC motor (12V as I recall).  They also had internal switching which was what mostly went out on them.  Haven't bought one in years.  Last I got from Autozone ($70.00 then) -- number years back.
Quote from: dw85745;351750
jpc647
I guess I can take pictures and you could compare? Or take pictures of you're and I could tell you?
